Ga door naar hoofdinhoud
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Vragen Bekijk alle
Which is power connector polarity?
I would like to adapt a power supplier of mine for my old 3DS (maybe building up something like a dock-station), I found specification of the input current (4.6V, 0.9A), but I have no idea about polarity of the connector. Which is + and wich is - ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi Mick,
For battery connector: When you open the 3DS it tells you which pin is plus and minus on both the 3DS battery slot and the battery itself. You shouldn't need the middle pin to turn it on i don't think.
For the charge port at the back: There are only 2 pins. Set it on a desk with the port facing you. Left is - and right is +
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Do not confuse the polarities unless you want to fry your 3DS, permenantly.
door
What is left if you hold it upside down, is the rounded corner down?
door
Voeg je antwoord toe
Mick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 57
Altijd: 973
