Ga door naar hoofdinhoud
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Vragen Bekijk alle
How do you fix a Mac backlight?
My friends’ mac had the spotlight issue on the bottom of his screen and a few minutes later the backlight went out. Wanna know if that’s something I can fix. I have the pro-tech kit and I know how to fix iPhones and Windows laptops but I’ve only ever explored a mac and not fixed one.
Is dit een goede vraag?
1 Opmerking:
This is a known issue: The Design Flaw Behind MacBook Pro’s “Stage Light” Effect And 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists
As it turns out there is a extended warranty program for your system! 13-inch MacBook Pro Display Backlight Service Program
So take advantage of the Free Repair!
door
Voeg een opmerking toe
1 Antwoord
Hi Matthew!
Great question!
  1. This issue IS fixable despite what the big bitten fruit may claim.
  2. This issue will require more knowledge and tooling than a Pro-Tech kit alone. This repair will require board level diagnostics and micro-soldering to repair most likely - although it is certainly possible that replacing the display panel alone may resolve the issue.
  3. I would advise testing with a known-good display panel and then proceeding from there.
Cheers!
Joshua
Was dit antwoord nuttig?
Voeg je antwoord toe
matthew davis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 54
