Ga door naar hoofdinhoud
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Vragen Bekijk alle
Looking for battery removal (and replacement of same battery) tutorial
I’m looking for a tutorial for the A1398 that shows battery removal and re-installation of the same battery for a track pad replacement. I’ve watched many videos and none show this so far. Even the one I found hosted by iFixit wasn’t the exact same computer as I have so there were parts where it was very hard to follow and I was extremely worried about damaging the battery.
Please, any links that show how to remove and replace the same battery would be seriously appreciated. Thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The steps are the same across almost all of them as far as I know. Be careful, and go slow. You could even make a guide for your model if you want! The batteries should be the same.
Was dit antwoord nuttig?
1 Opmerking:
Yeah, the steps are, more or less, the same. However, there are particular nuances that have made me not comfortable going off the “general concept” from the videos I’ve seen so far. For instance, the parts where the batteries are particularly brittle aren’t the same. The way the wires are run, just little things like that. If I break this battery the computer will sit for a while under I can afford to buy a new one that is why I’m very paranoid about doing this. I’ve actually attempted this like 3 or 4 times so far and stopped because the alcohol wasn’t relieving the adhesive very well and it was very possible I’d break something trying to remove it. If I had a video or page with photos or whatever that had my exact model I’d feel wayyyyyy more comfortable doing this.
Also, all the videos and pages I've seen and read so far are all "battery *and* trackpad replacement". So they aren't carefully taking the battery out. That is why I haven't done it yet. I need to find something that shows how to remove the battery carefully with the intention on it being reused. I'm not even sure what kind of adhesive I need to replace it to be honest.
door
Voeg je antwoord toe
didymus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 27
