Late 2015 iMac Black Screen with Chime but no #3 LED
I recently removed my iMac late 2015 i5 27” screen to upgrade the hard drive. (Something I’ve done successfully before). Upon re-assembly, the machine would not boot. Got a chime but then a full black screen.
I removed the screen again, checked all of the connections, and they seem good. I get LED #1+#2 lit up on the diagnostic, but no #3. I’ve read that this means the the video card and logic board are not communicating.
I’ve tried resetting the PRAM and the SMC with no luck.
- Questions:
- Are there any further suggestions about what to try to get it running again?
- Is there any value in pulling the whole thing apart to replace the PRAM battery? I read one place this could be a fix, but it seems like a lot of work if it’s a dead end.
Thanks for any help.
Update (03/16/2021)
I took the entire iMac apart to replace the PRAM battery. This did not help, but it was a ton of work.
Still getting only LED#1 and LED #2 lit up with a chime and a black screen.
I DID plug into an external display that that WORKS. I put some fan monitoring software and got the following showing no fan sensor for the LCD Flying Lead.
I assume this is the thermal sensor monitor on the display. Either it’s damages or disconnected.
Does anyone know if THIS is the sensor?
AND does it seem like this might be a solution to getting this machine up and running again. I don’t want to quit on it!
Thanks
Update (04/23/2021)
I’m throwing out one last request for help with this machine. (Late 2015 iMac)
I have scoured the forums here and elsewhere and have tried every single thing I’ve found short of replacing the logic board. Are there any other ideas before I have to strip this iMac down and sell it for parts?
Summary of the problem:
Symptoms:
- Screen stays black
- Fans go at full speed
- Computer boots and work with an external monitor, although throttled down due to fan issue
- Flying Lead Sensor still doesn’t show up in iStats.
Repair attempts:
- Replaced LVDS Cable
- Replace PRAM Batter
- Reset PRAM and SMC
- Replaced screen with know working screen (symptoms were exactly the same)
- Replaced the thermal sensor cable on the back of the LCD panel.
- Fully removed all internals are replace to check every cable connection was firm.
- Ran Apple Hardware test got these results:
- There may be an issue with the System Management Controller (SMC). Reference Code: PFM006
- There may be an issue with the display. Reference Code: VFD001
Anybody here have any further ideas for a fix?
Thank so much in advance.
Is dit een goede vraag?
Great question and self-searching diagnostics. If you haven't considered it already, try disconnecting the reconnecting the video card as you may have damaged (or disconnected) some cables even slightly with a misalignment. (it happens to all of us).
door DunCanP
Thank you for the suggestion. In researching the disassembly of the iMac, I can't quite see where I would do this re-connection of the video card. It seems that all of the GPU components are soldered onto the logicboard. (see step 8 here)
iMac Intel 27" Retina 5K Display Teardown
Do you have any further insights about how I would acomplish this disconnect/reconnect of the Video card?
Thank you!
door Eric Bryant
