Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
Microphone problem after screen replacement
Hello.
When I replace the display with a new LCD, then I screw the tape with (speaker-microphone-face id etc), while recording the front camera I hear a slight squeaking in the background. But when the tape is on the outside of the screen, it is all ok. Is it maybe some kind of lack of grounding in the screen? Is there any method to change it? (in the original display everything is fine) Any suggestions or help are welcome.
Is dit een goede vraag?
1 Opmerking:
Yes, I checked everything. This little golden clip does not eliminate the problem. Flex is ok, everything works fine on the original screen.
door
Voeg een opmerking toe
3 Antwoorden
Did you place back the little gold grounding clip as can be seen in step 22 of this guide? iPhone X Vervanging van het scherm
Also double check the flex cables to ensure they are not damaged.
Was dit antwoord nuttig?
1 Opmerking:
door
I have 350 of the same replacement displays, I checked 30+ lcd's and they all have the same problem. (little noise - “piiiiii” when i recording front camera)
This is an issue with bad quality replacement frames. Sometimes it is easier to use a good quality screen to save the hassle.
2 opmerkingen:
So you are saying that in my replacement displays, weak aluminum or other metal was used during production, which interferes incorrectly with the phone casing?
door
Voeg je antwoord toe
Lucas Szeyk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 642
