Ga door naar hoofdinhoud
Touch id and home button cause iPhone 7 in apple logo loop
Some days ago i clean the front and back body of iphone 7 with a wet cloth after some days it’s home button and touch id not work properly it works sometimes and sometimes it didn’t .when i restart the phone ,it stuck on apple logo loop.then i open to repair phone and i plug out the home button strip and plug in again ,it turn on without any problem and work good when i assemble and restart ,it again stuck on apple logo then i plug out the home button strip and iphone starts working good without home button. Now what should i do now ?should i replace it or can i fix it .
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Take out carefully the home button and clean it with high percentage alcohol, I think when you have cleaned it it will no longer start in a loop.
Was dit antwoord nuttig?
2 opmerkingen:
What should i clean ? The strip or touch id?
door
Clean the front and back side of the home button and flex connector. Use a soft toothbrush and some alcohol, wait until everything is dry before putting it back.
door
Voeg je antwoord toe
John wick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 45
