Ga door naar hoofdinhoud
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 Vragen Bekijk alle
Is my LCD toast? Green lines at bottom
I am trying to repair my cracked screen on iWatch series 4.
The screen was working prior to repair, it was cracked around the edges. I started removing glass. Now the screen is not working . It had green lines at the bottom. I'm assuming one of the edge cables is broken . Can I fix it or is my LCD toast.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sorry you’ll need a new display assembly [[ ongeldige onderdelenlink ]]
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
There is no Micro repair method ?
door
@sendo - Sadly no, its part replacement time.
door
Thanks Dan. First attempt at fixing iwatch . Second attempt cut to deep and collected the polariser on S2. 3rd , 4th and 5th attempt successful. Live and learn. Thanks Dan.
door
Yes it does take a bit of skill, happy in the end you got it working again! - Don't forget to accept the answer
door
Voeg je antwoord toe
Peter Senden zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 258
