Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Vragen Bekijk alle
Display damaged while replacing bezel sticker
Dear all,
I have just damaged the display of my mac book when replacing the front bezel cover following this explanation:
https://www.youtube.com/watch?v=zmY49eyn...
I damaged one of the organge/brown connectors:
This small scratch on that part has led to a huge dead area of the display and some flicker:
I’m devastated because I had successfully replaced the battery a few days ago following the ifixit guide and thought I could finish the job by changing the bezel, which was cracked and aesthetically unpleasing… So I guess I have destroyed the display while trying to carry out an unnecessary fix… Is there a way to replace just that scratched connector or must one really get a whole new display?
Thank a lot in advance for your help!
Best,
Albert
Is dit een goede vraag?
1 Opmerking
Thank for the reply! I thought and feared that would be the answer, but wanted to double check before sobbing in the shower...haha Anyways, do you think it is a good idea to buy this replacement display?
https://www.amazon.de/dp/B08979R8PH/ref=...
Otherwise, would you suggest another place to get such replacement (in Europe, preferably)?
Thanks a lot in advance for your help!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I’m so sorry! It kills you when you’ve gotten so far and bam! The very last thing wipes out all your efforts!
Sadly, there is no means to fix the ribbon cable. Your only option is replacing the full display assembly.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Albert zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 394
