Ga door naar hoofdinhoud
A cellular device manufactured in 2004 by Sony.
2 Vragen Bekijk alle
Flashing red light on joystick
Yesterday, on my ancient but trusty T630, a red light started to flicker regularly. I don’t remember seeing this before. Today after turning it on, the light is gone again. Could someone tell me the meaning of this light? I have looked in the user manual and can not find anything!
Is dit een goede vraag?
1 Opmerking
A likely reason, not sure if it applies to my old phone though...
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Did you charge it before turning it on today? Sounds like a low battery indication.
Was dit antwoord nuttig?
Hi gmantunt,
The phone is turned off and put on the charger every night. It has to be off, because for some reason it has a problem charging correctly if the phone is on. So I don’t think it would be a low battery - the battery icon didn’t indicate it anyway. I suppose it could be a glitch of some sort that resolved overnight? Anyway, I appreciate your taking the time to answer!
1 Opmerking:
No idea what it could be then. Well as long as the phone is working correctly there's not much to fix right?
door
Voeg je antwoord toe
Lami zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 139
