Ga door naar hoofdinhoud
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Vragen Bekijk alle
cannot transfer my memo files
I cannot transfer my Memo files from my Samsung s5 to my pc. I have used all apps when I connect my pc and do a search for .Memo nothing appears
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
1.Connect the Samsung mobile to a PC.
2.A prompt will appear on your smartphone, ‘Use the Connection For’. You need to tap on ‘Transfer Files’.
3.The name of the device will be visible on the ‘File Explorer’. Enter the device.
4.Inside the phone’s directory, tap on the ‘Search’ bar on the upper right side and type ‘Memo’.
5.A folder will show up. Copy all the content of that folder and paste them inside the computer.
Was dit antwoord nuttig?
Score 1
You can transfer all your memos By screenshooting them and Transfer them to your micro SD Card, then get micro SD card to USB Adapter and your done.Now you can transfer it to your Computer!
Voeg je antwoord toe
MIKET zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 289
