How do I reattatch a joycon rail
so i broke off my right joycon rail and have no modding experiance
Is dit een goede vraag?
Depends how it’s broken. Did you drop it? Or pull it? If the rail is still intact, you have to carefully open the Joycon, put it back and close it. For that you’ll need absolutely a TriWing (Y head) screwdriver.
If the rail is broken, you’ll need a new one.
Same thing if it’s the rail on the Switch’s side.
Was dit antwoord nuttig?
How do I put it back in?
@Tgw Gaming We can't give you an answer without knowing just what's broken. Is it the rail on the joycon, or the rail on the Switch?
The rail on the joy con
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 311
Depending on how you broke it you might be able to but it back on. Is it possible you can attach a photo of the joycon?
door Bri
same problem here. are the two flat cables from the rail intact like mine are?
door Hamm Khan
