Earphones work but charger doesn’t work?
So I was charging my phone, I plugged in my earphones to listen to something and then when I went to charge my phone it wasn’t charging. I’ve tried hard resetting the phone and cleaning out the charging port, even checked for software updates. It’s weird because if I turn the phone off and then plug the charger in, the phone will turn on as if it’s recognising the charger but the battery isn’t charging?? Help please??
Is dit een goede vraag?
@tuiyaatribe Just to be clear, you were charging your phone, DISCONNECTED the charging cable and then plugged in your earphones to listen to something and now the iPhone doesn't charge?
Can you confirm you can wirelessly charge? I am assuming you are using all Apple geniune cables and headphones as after-market ones can be sketchy.
door DunCanP
