Ga door naar hoofdinhoud
Dell Inspiron 9100-laptop met een dubbele rij aansluitingen aan de achterkant en een 15,4-inch scherm
Laptop screen flashes, 3 lights come on (not flashing), turns off.
When turning on the laptop, the screen flashes once, nothing comes on. The power light comes on but no response from the hard drive. 3 lights come on but then turn off after 2-3 seconds. Battery light comes on and appears to be charging. The fans do not come on. There is no activity and doesn’t go through POST. Steps I have taken are:
1) Remove the power lead (Dell original charger at 150W. Light is green on charger so appears to be working.)
2) Take battery out.
3) Hold the power button for 50 seconds to drain the static (if any).
4) Put the charger back in and not replace the battery. Same response.
5) Removed the RAM and replaced it. Same response.
6) Removed the hard drive. It should boot without to show the BIOS. Same response.
7) Changed the CMOS. Same response.
Is there anything I’m missing? Is the motherboard gone because it appears to be holding electricity as the power light remains on. Also the battery light shows it is charging.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
The first thing you can try is connect an external monitor to test the display.
If the screen is blank on an external monitor also, then it could be an issue with the video cable.
Try replacing the video cable or using a different video cable if you have multiple connections options like DVI, HDMI, etc. If using VGA works, then it could mean there is an issue with your HDMI or DVI cable.
If a separate monitor works fine, then it could mean the power supply is bad on the original monitor. Try replacing the power supply and see if that fixes the issue.
Otherwise check out the post for more methods.
https://www.partitionwizard.com/partitio...
Was dit antwoord nuttig?
Voeg je antwoord toe
Jez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 538
