Ga door naar hoofdinhoud
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 Vragen Bekijk alle
Why is Screen only showing backlight?
I am working on a Mini 2 and doing a LCD And Glass replacement. This was/is my first mini 2 ive taken apart so i wanted to test my work before sealing it back together. It boots fine, i see the apple logo a can navigate the OS once its fully boots. But once i let it sleep or even tap the power button then try to turn it back on, i only get a backlight. I know it is functioning still because i can hear the charge sound from plugging it in. Also pressing the power button till wakes and sleeps the lcd as it should, but its only getting a backlight.
I had a theory that it might be some silly apple sensor stopping it from working properly till its fully sealed back up, but i cant find anything that supports that.
Thank you for taking your time to read and help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Try restoring it maybe its a bug,or the smart magnets could be stopping it.Try the mute and unmute button.
Was dit antwoord nuttig?
Voeg je antwoord toe
Kyle Sargent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 38
