Ga door naar hoofdinhoud
The Apple Magic Mouse is a multi-touch mouse manufactured and sold by Apple Inc. It was announced and sold for the first time on October 20, 2009.
Dent in right click area
I bought a used Magic Mouse (the battery version, not the rechargeable one) but it won’t right click at all. After looking there seems to be a big dent under the right click area.
It doesn’t show up well on camera but it’s there:
Can I safely fix or remove it? Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ouch the aluminum shell is bent up so its stopping the plastic part to go down.
You might be able to bend it back wedging between the surfaces carefully prying. If you can see of you can disassembly it review this for an idea what’s need Magic Mouse Teardown
Otherwise you’ll need to get another, sorry ;-{
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks Dan. I might try pull it apart and see what I can do to pry it back. If my luck isn't there it's alright, it still kind of right clicks if you position your finger right :-)
door
Voeg je antwoord toe
Tony zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 340
