Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
20 Vragen Bekijk alle
Joy-con stuck on nintendo switch and broken.
My Joy-con is broken and it is stuck on my Nintendo Switch… Is there any way to remove the remaining part of my Joy-con from the Switch?
Is dit een goede vraag?
Score 6
8 opmerkingen
My long distance boyfriend had this issue for at least 2 days, and he was a bit scared on how to fix it. This helped get those broken pieces off right away! Thank you, now we know just in case this happens again, since we do enjoy playing Minecraft every day
door
Ohh push from the back of the console down not in, got it now
door
Do you push it into the switch or away from it?
door
Which way do you push it?
door
This happened to me, the only thing I'm struggling with is putting the top back on...
door
3 commentaren meer tonen
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
I’ve figured it out by myself, but in case if anyone’s having the same problem as me, I’m posting this by my self.
You can try pushing the red part of the image all the way, and it will probably detach.
Was dit antwoord nuttig?
Score 24
16 opmerkingen:
Thank you. This has been the only useful thing I have found for the same issue. All fixed now!
door
i tried it didn't work for me, is there any other ways
edit: i tried again a few more times and the remaining piece finally got out! thanks
door
I had this same problem so now m parents are gonna kill me but I saved my switch. :/
door
thank you so freaking much!!
door
THANK YOU SO MUCH!!! However… is there any way i can get the orange straps back into the joy con?? Or would i have to contact support for this… i have no expire with unscrewing joy cons and stuff D:
door
11 commentaren meer tonen
i don’t have a red thing 😬😬 my parents r going to kill me…
Score 2
4 opmerkingen:
Oreo, when Yoon said "the red thing", he was talking about the part of the joycon still stuck on the console that he'd *circled in red* in his picture. Find that same spot on your joycon rail and press it and it should slide out. When your joycon is intact, that's the part the release button moves against when you press it.
door
ohhh my bad i the picture it looked like it was red 🫣 but i figured it out but now i gotta figure out how to get the controller back on
door
What red thing I don't see it
door
Yeah for but my controller broke but didn't leave anything on the Nintendo switch and it was on the Nintendo switch idk how but that's lucky
door
Dose this work for the right joy con as well? I have the same issue rn. Thank you in advance
Score 1
2 opmerkingen:
it works on both so yes
door
Bro, literally happened today. BLESS YOU mother F'er. Forever thankful 🙏
door
Thank you for this. Slid right out! Life saver! Lol
My switch fell and now the black controller broke and now there is yellow wires
1 Opmerking:
You beautiful life saver you
door
Hmmm idk but you might want to go to a repair shop for that🤨
Voeg je antwoord toe
Yoon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 53
Afgelopen 30 dagen: 181
Altijd: 21,171
