Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
375 Vragen Bekijk alle
Phone restarts after 5m and is very slow after battery replacement!
Hello, I had a iPhone XS Max which needed a battery and dock connector replacement, but now the phone powers on but is extremely slow and restarts every 5 minutes. It doesn’t show the percentage of the battery as well… I ordered the battery for €40 and the dock connector for €15. Any idea what the problem could be?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
iPhone XS and XS max series have a serious problem. First, see the panic log from setting/privacy/analytic and improvements/scroll down and search for the panic log on which you got an answer. The various region among them ear speaker flex and charging flex, power switch flex may cause that problem. If you try this and you got such a problem still the same this tutorial helps you.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hey, thanks a lot for the tutorial. I think it is indeed the charging coil, becaus I overheated it with my heatgun... So I will replace that
door
Voeg je antwoord toe
Ingmar Prins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 552
