Ga door naar hoofdinhoud
Repair and disassembly guides for Brother printers.
352 Vragen Bekijk alle
MFC-J430Wabsorber full No Purge plz need video How 2 change absorber
we are currently under lockdown here due to covid-19 and having trouble with my printer. I cannot go anywhere to fix it. I need help to fix my printer ASAP. Can you please help me?
I have a Brother MFC-J430W Printer. I had a problem with my black. I did many test printing and got some results. But it wasn't perfect so I decided to do a flushing by injecting some solution in the black ink nozzle. I did 3 flushings and now my ink pad absorber is full. It does not say error 46. and I don't feel comfortable to do a purge and set it to 0 because I Know for a fact 3 flushes is lots of liquid and surely must of filled the absorber pad. I searched everywhere on line for my model number mfc-j430w How to clean or replace ink absorber Did not find any video or information on how to do it. The only thing I found is this information:
How do I clean my printer ink absorber?
Take a bowl with warm water and add some soapy material.
Open the ink cartridge compartment.
wait for ink cartridges and disconnect the printers power cord.
Look black rubber frame under the ink cartridge.
pull the rubber frame out of the printer and remove ink absorber pads.
clean the pads in the bowl.
This information is not useful at all since I don't know where ink pad absorber is and how to get to it. Do you have a video for my printer to show me please
Thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi
Please check the service manual here : https://www.manualslib.com/products/Brot...
At page 234 the ink absorber box is listed with all its parts.
However, before you go ahead and disassemble the unit, make sure you have a new absorber box ready or at least new felt to replace the old one. You can get them cheaply on Chinese websites.
I did this for an Epson printer and there is no practical way to actually clean the old felt. It really needs to be discarded.
Also, make sure you wear gloves and work on a surface which you don’t mind staining and have plenty of paper towels available at hand because once you remove the tubes, ink will leak. Ink on your hands will go away in 1-2 days. On your clothes in 1-2 minutes but only with a pair of scissors :)
Cheers!
Bogdan
Was dit antwoord nuttig?
1 Opmerking:
Hi Bogdan. Thank you for your information. I see this is more complicated than I thought to dismantle full printer. I am not able to do that. And from what I had read online seemed to be easy process as I wrote on my question before. I am not a wiz at technology. Will not be able to completely open printer, have no clue what I am doing
door
Voeg je antwoord toe
Patty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 591
