Ga door naar hoofdinhoud
The T Flight Hotas 4 is a joystick controller manufactured by Thrustmaster in 2015 that is used for specific flight simulation games. Model number 4169083 is currently supported by PC and PlayStation 4.
12 Vragen Bekijk alle
Sourcing a replacement potentiometer for t flight hotas
Try as I might, I've not managed to source a replacement potentiometer for my hotas. Is anyone aware of a company that might sell these parts? Thrustmaster customer services were no help at all and as far as they're concerned I should chuck my beloved flight stick on the scrap heap
Is dit een goede vraag?
Score 2
3 opmerkingen:
I have a similar issue with the T.Flight Hotas X throttle potentiometer, tried cleaning original but no luck.
I’ve ordered a couple of pots that might do the job , I’ll post back here with details and part numbers if it works out.
If you have any details on the pot in question post them here and I’ll see if I can help.
door
did you find any potentiometer that worked?
door
None that were cost effective. I suspect that the answer below may have been the right one, but I'd thoroughly ruined the existing potentiometer by then!
door
Voeg een opmerking toe
1 Antwoord
This may help. Replacement pots for TM HOTAS. https://www.radwell.com/en-US/Buy/CH%20P...
Was dit antwoord nuttig?
1 Opmerking:
If you're having erratic yaw problems I found the fix for that. No parts needed. I just did this to mine and it works. https://imgur.com/gallery/ob06FmA
door
Voeg je antwoord toe
Joe Lewis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 46
Altijd: 1,998
