Ga door naar hoofdinhoud
Model A1213 / 8, 16, or 32 GB capacity
216 Vragen Bekijk alle
My touch is locked and disabled
I bought a 8 gig touch and it's disabled and also locked. how do i unlock it and get it not disabled i don't know the lock combonation
Is dit een goede vraag?
Score 3
1 Opmerking
mine is the same way:((
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Put it in DFU Mode, then connect it ti itunes, and restore it.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Can you link to directions for DFU mode?
door
Here's a link, it's hard to explain, but there are step-by-step instructions:
http://www.iclarified.com/entry/index.ph...
door
I tryed doing that it starts up with the apple very slow then does same thing stops at disabled again
door
weird, that should work, are you sure you are doing it correctly, it took me a couple tries to do it when i jailbroke my iPod, if you do it right, it will look as if it has a blank screen, and Windows will show somthing like "New device found, iBoot USB Device" then you can open itunes, and it will give you the option to restore it.
door
Score 1
please help me unlock My lpod touch made in 2010 using My gpad 8
My 1st generation iPod is disabled for 23,610,434 and I don't know the password and don't have an apple computer. So how can I get into my iPod?
Voeg je antwoord toe
murray zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 13,094
