Ga door naar hoofdinhoud
Polaroid Sun 600 LMS instant camera. Released 1983.
Won’t turn on
I had used it last around 2 months ago, but now it won’t turn on after putting the film pack in. i tried different film packs, and it made no difference.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi
Try to measure the voltage across the 2 “pads” of the film pack. This should read 6V. If this is not the case, then the battery inside the film pack is dead.
Alternatively, you can try to make a test film pack : https://www.youtube.com/watch?app=deskto...
If all checks out but the camera still refuses to turn on, I would dab a swab in Isopropyl alcohol and clean the contacts inside the camera.
Cheers!
Bogdan
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Trevor Anderson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 1,149
