Ga door naar hoofdinhoud
A digital camera released by Fujifilm in March of 2012. The model number is HS30EXR.
How could I replace the triPod mounting hole?
The tripod mounting hole or tripod thread, has cracked in the camera and isn't very usable anymore. It cracked probably due to the fact it was plastic, is there any way i could add a new one/replace the damaged one?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
You could try putting in a new threaded insert like this one: https://www.amazon.com/1-4-20-Threaded-I...
Was dit antwoord nuttig?
That's a good solution that I'd consider, but how do I fix one of these into the camera? Do I need to remove the old tripod socket? Keeping in mind, it's plastic.
Voeg je antwoord toe
Piotrix zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 314
