Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
2, 2,26, 2,53 of 2,66 GHz Core 2 Duo-processor gebruikt DDR3-RAM. Grafische processor is FX9400 met 128-256 MB VRAM, afhankelijk van het geïnstalleerde systeem-RAM.
Won't Boot into Windows After Partition Resize
Yesterday, I was using my mac mini in windows, and was downloading, and copying some Disk images, and windows started giving me messages telling me that the disk space was low. When i created the partition, i set it for 15GB. since the drive is only 120GB with 70GB free. I decided to resize the disk, by creating an image of the disk, (in disk utility, and then used the boot camp utility to remove the partition. I then used it to create a larger partition (30GB) and then used disk utility to restore the drive from that image. It did, and after about 1 hour, it was done. I then went to startup disk, and selected "Windows" on BOOTCAMP (My Windows Drive) and rebooted it. After about 5 minuted of a black screen with a blinking white underscore, i rebooted it, held option, and it gave me a list of boot drives, and the "BOOTCAMP" wasn't one of them. I tried reseting the PRAM, PMU, and a lot of other things, but no success.
Any Ideas?
Thanks
Also, it was running Windows XP Professional SP3
And had the FAT Filesystem
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
I'm guessing it was a formatting issue. See, Mac OS creates FAT partitions, but windows likes NTFS, and usually that's what you have to reformat to in the installer. So it's possible you tried to restore an NTFS image to a FAT image, which could result in corruption and stuff. Hopefully you had a backup. I hear there's a tool called Wincloner or something like that which helps with this stuff. Great for quick resizes I hear.
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
unfortionatly, it's too late for me to use winclone, i already imaged the drive, and erased it, and winclone will only restore if it created the image. any other ideas?
door Deel
Do you have that original image? Or maybe you can try mounting the image you already have separately. Or running any recovery tools on it.
door Deel
I have the image, on the Mac OS Partition of my mac mini, when i restore it to the bootcamp partition, it works, and the startup disk finds it, but under the info, it says "Bootable: No" and the mac can't boot of of it, and disk utility can only restore the disk from that image. I can mount the disk in mac os, but you can't boot of of somthing like that. Also, converting it From DMG to ISO didn't help either.
door Deel
What format is the image?
door Deel
It is a DMG, but i just decided to install Windows 7 Pro on it, and copy files off of the dmg.
door Deel
1 commentaar meer tonen
Voeg je antwoord toe
Chris Green zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 33
Altijd: 6,812
