Ga door naar hoofdinhoud
Windows 10 is een hoofdversie van het Windows-besturingssysteem. Het werd uitgebracht in 2015.
22 Vragen Bekijk alle
My computer will not turn on
My computer has been having problems for well over a year now. A while ago it would not turn on unless it was plugged in so I started using my moms battery and my computer would turn on then but it would shut off later on. The battery works perfectly fine on her computer but not on mine.My computer will now absolutely not turn on at all. I'm thinking there is something wrong with the inside of the computer but I have no clue what.
Is dit een goede vraag?
1 Opmerking:
Hi @na7a133
Let us know the exact model of your computer, so we can check and provide you with better advises to check on it.
There could be some hardware issues on your computer.
door
Voeg een opmerking toe
1 Antwoord
Since you are able to use your laptop when it is plugged-in, more than likely its good and your battery has reached its end of life. You may look at the specs on it and see what the supply output voltage is and check it with a multi-mete. Replace your battery and it should all be fine.
Also make sure to check out these methods the post provided.
https://www.minitool.com/data-recovery/f...
Was dit antwoord nuttig?
Voeg je antwoord toe
Natalee Brown zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 109
