Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Vodafone is een mondiaal telecommunicatiebedrijf gevestigd in Londen, Engeland. Het bedrijf produceert mobiele telefoons naast het exploiteren van mobiele netwerken.
How do I replace the screen?
My screen is cracked on my phone, and I would like to repair it. Is it possible to do this myself? I have limited experience of doing such things but I am quite careful and patient with delicate things, and would rather not get a new phone if I can repair it. Thanks for your help!
Is dit een goede vraag?
1 Opmerking
Hi Virginia,
If you want help, you must state your exact make and model of phone.
Otherwise no one will be able to help you. They are all different.
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Depending on the phone you have you can probably even look it up on this website for your phone model/ what your phone is called (persay LG stylo 6) and there should be a screen replacement tutorial for you, so yes if you have all of the right tools you can fix your screen yourself (you may have to order a new screen and the tools if you dont already have these items you need).
Was dit antwoord nuttig?
Score 2
1 Opmerking:
See the comment on the original question, which your answer is a word for word copy. Assuming you have the same issue and aren't just a troll, we still need to know what model of phone you have.
If you don't provide that sort of information, I'll archive your question as unanswerable.
door Deel
Voeg je antwoord toe
Virginia Vargo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 38
Altijd: 592
