Ga door naar hoofdinhoud
A2116 / 2019 / 3,6 GHz quad-core i3, 3,0 GHz 6-core i5 of 3,2 GHz 6-core i7 processor. Uitgebracht op 19 maart 2019.
What is this weird tube?
We opened up this machine to inspect the internals and found this strange tube floating freely inside the system. It was completed detached from any other component and was free to move and slide around inside the machine. Does anyone know what this is or why it was in this machine? I’ve attached three pictures of the object.
Afbeelding
Afbeelding
Afbeelding
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Alright, I think I figured it out. The loops around the green tube are the same kind of loops you see highlighted in this picture.
Afbeelding
There’s also a peel-able adhesive strip on the back, so my guess is this is something the manufacturer sometimes uses to apply those little loops. May have been a leftover piece that accidentally fell into the machine.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Yes! That's an EMI gasket! The tube is pulled out after its mounted. Clearly it was dropped in by mistake!
door
Nice! Thanks for the explanation!
door
Unless I’m missing something, I don’t see it present in this breakdown:
Demontage van de iMac Intel 21.5" Retina 4K Display 2019
From the looks of it, I honestly have no idea what it would be doing inside a PC. Curious to see what it turns out to be but I wonder if someone it was an accidental inclusion from the vendor or someone who worked on it previously?
Score 1
Voeg je antwoord toe
Zach zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 494
