Ga door naar hoofdinhoud
Reparatiehandleidingen voor beeldschermen (of monitoren) van computers of andere apparaten met video-output.
505 Vragen Bekijk alle
What have to my screen? top screen appears at bottom
Can anyone diagnose this problem? I've been trying many methods it doesn't seem to get better, My biggest issue now is how can I call this monitor issue to find the right to fixing it. Is it a hardware or software failure?
Model: Acer g206hql
Is dit een goede vraag?
1 Opmerking:
hey man did you find a fix or the cause please let me know
door
Voeg een opmerking toe
1 Antwoord
Hello,
Can you post any internal screen and windows settings?
How is it connected? Can you switch cables?
Can you try another device working with the same issues on this monitor?
Was dit antwoord nuttig?
2 opmerkingen:
Thank you for answering. I swapped the cable(VGA) with my second monitor and the same issue still there so I suspect it might have to do with my monitor hardware or else because the monitor was functioning properly a night before I open it again, thus I've tried without connect the cable the issue remaining
door
So theres no second device (Laptop, another PC) to test on?
Are the outputs both on your GPU? Can you try an on-board motherboard output?
Then maybe your drivers corrupted, maybe uninstall graphic drivers and try again.
door
Voeg je antwoord toe
Waris Thongkaew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 579
