Ga door naar hoofdinhoud
iPad Air Wi-Fi + Cellular, modelnummer A1475. Verkrijgbaar in Spacegrijs of Zilver, met 16/32/64/128 GB configuraties.
PMIC Replaced - Missing voltages
I have an iPad Air (1st gen) which I have replaced the PMIC. The reason for that is because the iPad charges only when it was switched off.
I have lifted the following pads during removal of the PMIC:
  • B17
  • B16
  • B15
  • C16
Dont know If this is the cause of the problems below:
  • No backlight (filters are good)
  • Missing voltage on PP3V0_SPARE1
  • Missing voltage on PP3V0_S2R_SENSOR
  • Missing voltage on PP3V3_ACC
  • No Heat on the board, and I can see apple logo on screen without backlight looping.
Anyone can point me in the right direction or explaining those missing voltage lines could be a BIG help understanding the situation.
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
hello Peter,
too high temp and flow you use for taking off a glue and a ic. It seems like cpu overheated. Have you stencil for reballing?
Was dit antwoord nuttig?
6 opmerkingen:
Yes! I have used a brand new PMIC already reballed.
Also I have measured around all Caps with Multimeter Diod mode wich resulted NO short on the board.
door
Or you suggest I should reball the CPU???
door
this is dependent to board measurement. But it looks like. I would measure RAM and NAND beforehand but it looks like yes, I would do a CPU reballing.
door
sometimes, problem is in technical's hand work. Are you sure IC is sitting down correctly?
door
A smudged the corners and it seems ok....
door
1 commentaar meer tonen
Voeg je antwoord toe
Peter Hupuczi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 939
