Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor bedrade of draadloze apparaten die internetverbinding bieden.
My router doesn't turn on
Yesterday, I got a router from my ISP and it has not been switching on at all. At first glance, there were no signs of life. I eventually settled for opening the device, and heard a continuous clicking sound when the device was on. After closer inspection, there were two LEDs, each with a green and red light rapidly flashing. The router otherwise shows no signs of life, wifi does not work, and ethernet doesnt work either.
Can you help me?
Thanks
Is dit een goede vraag?
6 opmerkingen:
Hi,
What is the make and model number of the router?
How did you get the device to turn on when you said that there was no signs of life?
Did you allow at least 5 -8 minutes for the LEDs to stop blinking and to stay permanently on indicating that it had initialized after being powered on. Some routers take a bit of time to initialize.
door
The router is a Comtrend VR-3026e VDSL, and I've had it running for over an hour, but still nothing. There is an on-off switch on the back which, when in the on position, starts the flashing lights.
door
@Nico Papamichael
Have you been advised by your ISP that the internet line connection to your premises has been established and that you can connect the router to the cable coming into the premises?
If the line to the ISP is OK and the router is connected to it, when you turn on the router it signals the ISP equipment and starts initializing to get the best signal. If there is no response from the ISP equipment it can't do this and it stalls waiting for a response.
door
I turn on the router and all that happens is the lights flash, and on my account page on my isp website, it says the router is offline, this is because the router does not switch on.
door
There are also no faults detected in my area, and my neighbours have the same router and ISP and this works. My phone line works for calls too
door
1 commentaar meer tonen
Voeg een opmerking toe
2 Antwoorden
Press and hold the reset button for 10 sec. it will restart and check after 5 min. if you are getting new wifi siganl.
if not
connect a network cable to the router ( LAN Port), and the other end to the laptop.
check if the laptop is connected to LAN, if not the router is defective.
if yes open the command (CMD or terminal) in your laptop and type ipconfig /all and press the enter key
it will give the ip address and gate way
enter the gateway ip address in the browser and check if you can access the router configuration page.
login to the site and configure the wifi.
Was dit antwoord nuttig?
3 opmerkingen:
is the ISP cable connected to the WAN port of the router
door
The isp cable is in the WAN port, but it acts like it is off when it is on, and it is not working
door
did you connect the network cable and see if the laptop getting connected if not the router is defective, if it is new you can claim warranty
door
The continuous clicking sound together with rapidly flashing LEDs usually points to a power issue inside the router, not a normal boot problem. Very often it’s either a faulty power adapter or failed capacitors/power circuitry on the board itself.
Since neither WiFi nor Ethernet comes up, the router probably never finishes booting at all. I’d first try another compatible power adapter with the exact same voltage/amp rating before doing anything else. ISP routers sometimes ship with bad adapters more often than people think.
If you were hoping to access the admin page through the usual router addresses (the kind of setup guides you see on sites like https://router-19216811.com/), that unfortunately won’t work until the device can actually complete startup properly.
Honestly, if this is a brand new ISP router, I’d probably stop troubleshooting after testing the adapter and just ask for a replacement unit. The clicking noise is usually not a good sign.
Voeg je antwoord toe
Nico Papamichael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 43
Altijd: 497
