Ga door naar hoofdinhoud
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
20 Vragen Bekijk alle
no connection or charge, but reboot when powered down
my iPad Air does not connect to a pc via original apple cable. It does not charge when put in an outlet, but when i power it down while hanging on the charger, it reboots so it must recognize something?
the screw is tight, i tried that already.
anyone got a clue?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
hello Niels,
what screw you talking about? Who told you this?
seriously now, your problem is related to damage to the charging port (flex behind a port) or the electronics in the charging circuit. Unfortunately, this still happens with ipdads. Either way, it requires expert diagnosis, skill and experience. If you know some about re-work of electronics you can repair it at home, if not, don’t do this yourself. Ipad is often damaged when attempted to repair by people with poor knowledge and poor experience (there are many of these in street workshops). Think about it when you take your tablet anywhere. Find a specialist, talk to him first. It will surely explain the problem to you, on the other hand - very simple and easy to fix.
  • regards,
Was dit antwoord nuttig?
Voeg je antwoord toe
Niels Van Osch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 22
