Ga door naar hoofdinhoud
De mainstream iPhone 2019 van Apple, die 20 september uitkomt, heeft een 6,1-inch lcd-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
475 Vragen Bekijk alle
NFC and apple pay problems
Just a quick question. Recently repaired the back glass of 11 however damaged the wireless charging coil. Ordered a new one and installed. Now Apple pay is not working so NFC is not working either. I just wanted to know if the coil is the NFC problem? Or is it the flex cable at the top of the phone that’s the problem? Thanks
Update (11/17/2020)
Any idea which one it is? There are 3 connectors coming from 3 different antennas at the top. I have highlighted them
Is dit een goede vraag?
Score 1
4 opmerkingen
After reconnecting all 3 of the connectors shown in the screenshot the NFC function worked. I still don't know which one of these was the problem but it seems that the connection was not passing the signal through. For anyone wondering how to test NFC I use NFC tags which I write to using a compatible phone and then just tap the top of the phones to see if the tag gets picked up.
door
Hello ! im having the same issue after change the back chasis, and apparently the nfc antenna is well installed, i dont know how to fix it.
door
Hello! I'm having the same issue after changing the full frame, and apparently, the NFC is not reading or even functional via Apple Pay. He broke my volume flex cable and told me that he will replace it as soon as he got stocks, I didn't bother to come back to him since he is far away from my place. I fully replaced the volume flex cable and got it to working. I thought this will fix the NFC problem, but it didn't. So, what is the other possible issue with this? Should I replace/try to reseat the Bluetooth antennas, but my Bluetooth is still working. Or should I replace the NFC coil for like the wireless charging for the back glass since its probably broken also since I can't use it also. Help me find a solution to this please.
door
@sergiorp Hello have you solve the problem?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It’s at the top of the phone, usually around the camera.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
I have updated the question highlighting the antennas. Any idea which one of them it is?
door
@iphonerepairtom were u able to figure out which antenna it was?
door
@picklefixesstuf Commenting as a separate answer so I can attach pictures.
door
The NFC antenna is frequently mislabeled as Bluetooth on vendor sites. It is generally mounted between the camera module and the housing.
It's difficult to find pictures of it in place due its positioning in the housing, but it's this one mounted into the side of the chassis here. It is the one with the screw on the inside of the camera cutout. In nearly all iPhones it will use the standoff which goes into the board near the camera as a grounding point.
Score 3
3 opmerkingen:
Alright. Thats the one I thought, I inspected that antenna last noght and it looked completely fine. I have also been told on other forums that the NFC is located in the charging coil, but im still not sure. I will just have to check both I guess. Thank you for your help
door
After testing I can confirm that it is the antenna u r referring to. Sorry for doubting u, I appreciate the help. Thank you
door
@picklefixesstuf No offense taken. There is a lot of misinformation surrounding those peripheral parts because Apple does not communicate that sort of thing, which means it's up to repair community to figure out what's what. Also I think it sort of makes logic sense for NFC to be tied into the charge coil. Nevertheless. Glad you got that sorted out!
door
Voeg je antwoord toe
Tom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 235
Altijd: 7,391
