Ga door naar hoofdinhoud
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Vragen Bekijk alle
White screen after Apple logo
I have a MacBook Pro 17’” late 2011 (MacBookPro8,3).
Problem: When I boot my Mac, after the Apple logo and after loading about 70% of the progress bar, only a white screen appears (slightly darker than the home screen) without going further (the Apple logo and the progress bar disappears).
I don’t know if I did something with an un-install of a teleworking program (Cisco AnyConnect) which it could not be completely uninstalled and installed with the necessary settings and I wrote in the terminal the commands I found here: Cisco AnyConnect Manual uninstall Mac OS
Also sometimes on the same day it disconnected the Bluetooth speaker I had connected on its own.
I closed the lid to put it to sleep and after about 2 hours I went to open it there was a white screen (while the lid was closed).
I have tried and entered Recovery Mode once, I entered Utilities I ran Disk Utility - First Aid for both Macintosh HD and MacOS Base System and managed to get into High Sierra. After working for about an hour, the screen froze, I closed it from the power button and since then I have not been able to open it again. I have done everything (reset NVRAM, safe mode, SMC reset, internet recovery ...) and it remains the same problem without being able to even enter Recovery Mode.
I ran the Apple Hardware Test many times and my results show that it has no problems (no trouble found). Also in the Hardware Profile, displays all the computer information.
The only upgrade I made was the RAM (16GB). I also put the original ram (4GB) but it remains the same problem.
I don’t know what to do. I would greatly appreciate any idea.
Thanks in advance and sorry if I got tired.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Sadly, you are hitting a known issue in this series.
The discreet GPU logic is failing! A capacitor might have broken down which might be all you need to replace, it also could be the GPU chip its self has failed.
Someone with deep skills is needed here to test out the caps and check the solder joints. Hopefully that’s all thats needed.
I had two of these which I loved and miss even today. I was pushing the GPU’s quite hard processing very large images, I ended over stressing them to failure.
Was dit antwoord nuttig?
2 opmerkingen:
Thank you very much for your answer. Yes, it is the most common problem for these machines, but the results of Apple Hardware Test show no problems. Shouldn’t this problem appear on the hardware test?
door
Sorry, Apple's diagnostics only goes so far! It can't access the GPU to test it.
door
Voeg je antwoord toe
Alexander Tsinioglou zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 92
