Ga door naar hoofdinhoud
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor. Released June 8, 2017.
176 Vragen Bekijk alle
Black screen lowd fan after update SSD and RAM
Hi all,
Imac 2017, 21,5 inch non retina. 18,1.
I updated my RAM from OWC and new SSD (old fusion driver) form Samsung 2,5.
The first run was good! Altough it took a while to load te screen.
The second run there was only black screen and lowd fan! No display.
At the first run the screen wasn't completly sealed I first wanted to test, it worked! Before the 2nd test I closed the screen with the tape.
What can be wrong and how can I fix it?
Thanks guys!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like the display cable came loose or got damaged. Sadly, you’ll need to take the display back off to inspect things. Make sure you follow the guide and use the proper tools.
Was dit antwoord nuttig?
1 Opmerking:
Yes, the cable came loose. Thanks
door
Voeg je antwoord toe
Rob Smeets zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 49
