Ga door naar hoofdinhoud
The PowerBook 100 series kickstarted Apple's line of PowerBooks.
20 Vragen Bekijk alle
Macintosh PowerBook 145 Screen Issues even after recap
Hi all.
I recently got a PowerBook 145 with startup sound chime, but black/grey screen (only the backlight worked).
So I decided to recap the creen board (I used 9x 3.3uF-63V capacitors instead the 35V original ones) and the inverter board with a 47uF-16V and 33uF-16V (tantalium) caps.
The problem is that, even with this cleaning with alcohol and recap, the display doesn’t work properly… now it turns whit and shows a series of vertical lines, but nothing else.
Is the display definitely broken?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Without having a second PowerBook which you can use to check out the display on all you can do is check the voltages.
My first Mac laptop was a 180c which I used for work, it was much lighter than my Compaq Portable III ;-} I had been using. And the screen was full color! The Amber screen my Compaq had was hard on the eyes!
Was dit antwoord nuttig?
Voeg je antwoord toe
lumia.nicola zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 308
