Ga door naar hoofdinhoud
Repair guides and support for top and front loading Whirlpool brand washers.
425 Vragen Bekijk alle
WTW6800WL1 Washer tries to spin but can't
My washer will wash and agitate just fine but when goes to the spin cycle, it tries to spin but it turns about 2 inches and looks like it is getting caught up, then it tries to go the other way and the same thing happrns. Keeps going right then left…
I was thinking the barring went bad, but I can free spin it just fine and it doesn't make any noise. Im getting code F71.
Thank you for any help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
F71 is technically a SUDS code. But it’s basically just saying it detects friction while trying to spin. Try a drain & spin with it totally empty. Still doing it? Ok. No friction or noise when you spin it by hand though. Ok.
Unplug it. Tilt the washer back so you can see underneath. You will see a plastic round rotor with one bolt in the middle. This bolt can back out over time, and should be checked and tightened if so. If that is the case - that is the problem.
Bearing replacement would make sense, but not really if you don’t hear noise.
If the rotor bolt IS NOT loose - I would replace the RPS Sensor on the motor. Google that procedure for the Cabrio if need be. PART NUMBER WPW10178988.
Again - this is all assuming that the tub spins freely, and there is no bearing noise.
If the RPS Sensor does not do the trick - main control board(no longer available): WPW10249237.
Good Luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
Wolfe pack zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 36
Altijd: 486
