Power Jack pin is bent upward inside.
I bent the pin down and the black plastic housing around got cracked and half of it came out. It should look similar as another jack next to it. Where do I get the part? How do I replace it?
Is dit een goede vraag?
2 opmerkingen:
Does it not work? Looks like it should
door
It works for now. The plug is very loose and won't charge unless I press the plug against the object to get a firm hold.
door
Voeg een opmerking toe
