Ga door naar hoofdinhoud
The Toshiba Satellite L875D-S7210 is a laptop manufactured by Toshiba and released in 2015. It is designed as a desktop replacement and operates on Windows 7 and above.
Cannot boot to windows
Can anyone tell me what “critical-process-died” means? That is the answer I get when trying to start my computer.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
The computer may have a virus. Run a virus scan program using safe mode. If there no virus, update device drivers. If you cannot, let me know if I can provide help by step by step using this application
Was dit antwoord nuttig?
Do you also have a problem of it doing anything after logging in if so your hard drive has died I would recommend upgrading the ram to at least 8gb and put windows 10 I know that it would work mine is running it now because I had the problem of logging in then everything just dieing the only thing is it would be a bit slower than normal
Hello @a123bonnie
If you have the chance to start your device in safe mode to test if the issue is with a recent installed application or if that let you login you can check the system opening the CMD with admin privileges and use the command sfc /scannow, to check the OS.
The error you mentioned can be happening due to so many factors but you need to discard if the issue is only with Windows OS or maybe there is a problem with a hardware component. Another good command that can help to check your computer is chkdsk /f C: to verify if your HDD is ok and no sector issues detected.
If you are able to start in safe mode, you can use System Restore to get back your OS at an older state point were you be sure the system was working correctly.
Test it and let us know,
Voeg je antwoord toe
Bonnie Williams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 19
Altijd: 157
