Ga door naar hoofdinhoud
Touch issues ONLY after I screw the phone back together
I replaced the screen on my iPhone 7, all touch is perfect (using outside of case with cables seated and brackets on over the connectors) until I screw together the phone again, and ONLY when I screw in the pentalobes. Then the touch is scuffed, with a 2cm dead zone a third the way up the screen and a tendency to randomly press anything on the very bottom centimetre of the screen, especially on the bottom right. I have inspected the screen and there’s some give on the lower half of the backplate which occasionally sticks back flush if you hold it together long enough so it’s like the shield above the home button’s adhesive has come loose or something idk.
The issue is super annoying and I struggle to complete normal tasks on my phone, so even a little help would be hugely appreciated. I’m honestly considering not screwing it together at all lmao.
Thanks guys
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Maybe try replacing the screen? (again)
Was dit antwoord nuttig?
Score 2
1 Opmerking:
ok chucked her out then back in there completely, even the earpiece connectors, removed the scuffed battery tabs that i suspected were messing with the screen (they were folded over themselves in parts) and even confirmed that the touch worked without the screen pushed back into the phone. Touch is still scuffed when phone screen is pushed in and the pentalobes are screwed in
door
Make sure you are using the correct length screw by checking it on the
1 Opmerking:
it's only screwing in the last two pentalobes at the very bottom that does it
door
Have you tried removing the backplate and then installing the display and screws?
Voeg je antwoord toe
Bill From Accounting zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 60
