Ga door naar hoofdinhoud
De Sony Cyber-shot DSC-T1, uitgebracht in oktober 2003, is een ultracompacte camera met veel geweldige functies, alles verpakt in een formaat ter grootte van een kaartspel.
Photos come out white and hazy
I stay in a very humid country, an dont often use my camera. I recently had the ccd replaced, but now i'm experiencing photographs that are coming out very misty, almost as if a fog was present on a clear sunny day. it appears on the preview on the lcd and when you transfer to a laptop.I'm not sure what has caused this but suspect its because i keep my camera in storage without charging for long periods.
Please help me repair this problem.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
first off I'd turn the camera on and examine the camera from the front to see whether there is any residue/fog/dirt etc on your lens or light sensor. If nothing is obvious then i would open the camera using thisguide and take a good look at all the parts for corrosion/mould etc. I think either your CCD connection has been effected by the humidity or their is condensation/mould on the light sensor (so that the camera thinks it's dark and is then overexposing your images) I would have thought that any condensation on the inner lens would have rendered images fuzzy/blurred/spotty, not over bright.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Sorry all contacts are mould/corrosion free, problem still exists. I could better explain the problem as being if somebody turned up the contrast a bit too much. The LCD Brightness and Backlight are not the problem, what you see on the LCD and the downloaded image is a picture with too much contrast. Areas in the picture where sunlight is in high concentration are really bright almost as if there was a flash of light in that area. if you inspect the lcd at an angle before a picture is taken you can see a large part of it has what appears to be a large white area, with the outer edges appearing normal. hope this helps
door
Mine did the exact same thing! Any help greatly appreciated
door
Voeg je antwoord toe
lyndon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 37
Altijd: 5,272
