Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Vragen Bekijk alle
Screen dead after back case replacement
Hi
i needed to replace the broken back glass on my iPhone 8 Plus which involves removing every component. I’ve done a few iPhone repairs in the past so I’m relatively competent. Everything has gone well up to the point of putting the logic board into the new case. One of the stand off screws near to the screen connectors has sheared off and the thread is stuck in the hole. Now the screen does not light up. Would this be the cause of the black screen?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The first thing you need to determine is if you have an image problem or backlight problem. I do know there is one backlight circuit under that standoff. You will need to get the diode readings from the LCD connector and compare them with a known good board.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
ian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 52
