Ga door naar hoofdinhoud
The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
The system doesn't turn on, but battery light appears now and again
I opened the system up, disconnected the battery and put in a charge cable. It hadn't turned on until then but it did show the orange light for a couple of seconds. I checked with a multimeter, and current seems to be consistent but voltage is all over the place. Is it likely to be a charge port issue or possibly the battery?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@playxenoblade we don't know where you measured for any voltages nor do we know what readings you got. At this time you want to start off with a new battery. If nothing else it will give you a known-well starting point for further troubleshooting. Let us know what you find out after you replace the battery with a NEW one
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
I measured at the point where the battery connects to the motherboard sorry. I think it may actually be the charge port so I'm going to try to replace that. Thanks anyway
door
@playxenoblade sounds like you have a plan :-) Let us know how it is going.
door
@oldturkey03 ok sure, I'll update you :) thanks for the replies
door
Voeg je antwoord toe
Dom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 114
