Ga door naar hoofdinhoud
This HD video recorder contains an excellent camera mode that records and detachable stereo microphone capsules.
7 Vragen Bekijk alle
Why does my Q8 Camcoder suddenly turn off during my recording?
My Q8 Camcoder sometimes turn off when I was recording. I checked the battery and SD card spaces they all look perfectly fine. It is not a problem caused by battery and storage space. I could not find the reason why the camera suddenly blackout during my recording process which makes me very frustrated, and I cannot make a complete recording since I can not predict when it’s going to be dead.
Is dit een goede vraag?
Score 1
1 Opmerking:
I try recoding my band and the camera shuts off after (Approximately) 45 minutes. I can't even film a whole set. Very disappointed in this camera. Would not recommend anyone to buy this camera at this point.
door
Voeg een opmerking toe
1 Antwoord
This is due to a limitation of the .mov file, which the Q8 and Q4 use to record. The maximum size a .mov file can be is 4GB. Once this limit is reached while recording with the Zoom camcorder, it will begin a new file to continue further recording , if this does not happen check in the settings to see if you can continue recording after it has reached the 4gb file size.
Was dit antwoord nuttig?
1 Opmerking:
What settings? There is nothing in the settings menu to adjust this that I can see.
door
Voeg je antwoord toe
Dailin Zeng zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 601
