Ga door naar hoofdinhoud
Released in 1988 as the successor to the SHS-10
Left channel sound low and hissing
The left channel is not changing volume and is stuck at being very low, it is also quite fuzzy. I can only hear any sound from the keys on that channel if I turn the volume all the way down as this stops any sound coming from the right channel.
This applies to the inbuilt speakers and the headphone port.
I’ve replaced all the capacitors and even the amp but it hasn’t fixed the issue. I think there might be a short somewhere on the board before the output is split but I can’t see anything.
Is dit een goede vraag?
2 opmerkingen
I also have an issue with mine
door
I just bought my shs 200 and suddenly the keys stopped working and when i try to play the built in beat sound thingy it'll glitch in and out and then eventually stop. HELP
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I followed the traces, seems that the issue is the potentiometer used to change volume, there’s a break in one of the slides.
Was dit antwoord nuttig?
1 Opmerking:
Joined the channels at the input and output on the pot, both speakers now working.
door
Voeg je antwoord toe
Jacob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 130
