Ga door naar hoofdinhoud
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Vragen Bekijk alle
I installed new memory but still get 3 beeps
I installed new memory & still get 3 beeps, have tried to reseat a few times, still same result. I did carefully vacuum inside, could I have damaged the logic board? The Mac was previously getting some lines on monitor Occasionally . Logic board was replaced 4 years ago. Thanks
Is dit een goede vraag?
2 opmerkingen
Are you sure you have the correct RAM?
Reference: MacBook Pro: How to remove or install memory
Does an external display show the same lines? If not then the internal display will need to be replaced.
door
Thanks Dan, yes I have the correct ram. I will try with an external monitor once I get it going.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It may be the case that one or both of the RAM slots have failed. If you haven’t already, you should try testing the system with only one RAM stick installed, first in one slot, then in the other. Then repeat with the other stick. If any of those configurations work, try to deduce whether or not you have a failed RAM slot, bad memory stick, or larger issue such as general logic board failure.
Also it would be good to verify the style of beeps you are getting at startup. You can use this reference. There are two types of startup tones that give 3 beeps and it’s important to distinguish between them.
Was dit antwoord nuttig?
1 Opmerking:
Thanks Zachary, I have tried the various fitting of the ram, and will look into the different beeps, Regards Rob
door
Well Sadly I suspect you killed your logic board with the vacuum!
The rushing air through the hose can build-up a static charge so when you touched the nozzle to your system you could have zapped it! The rooms humidity will effect how charged the air is, so a very dry room (in the desert) will be a huge risk and if you where just in the shower so your mirror is fogged up your bathroom would have the least risk!
If you want to get more out of this system I would strongly recommend installing a 2012 logic board. The 2011 boards have a weak GPU where the 2012 offers a much better GPU. The logic board is a direct drop-in with a slight modification to the LVDS cable as the Apple altered its supplier. A few strokes of a nail file solves that.
Voeg je antwoord toe
robert.monty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 426
