Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
Replacement screen blinks only during phone calls
I just replaced the display/digitizer on my iPhone SE with the iFixit kit (IF327-011-3), and everything seems to work as it should — until I make or receive a phone call. With the phone active, the screen starts blinking on and off, and I’m unable to turn on the speaker, use the keypad or even hang up. Oh, except when I can. Sometimes the screen will stop blinking and behave normally during a call. Or not blink at all. No screen issues when using apps on cellular data. I’ve powered off and re-started a few times, but no change. Suggestions?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Make sure the Ambient Light Sensor is lined up properly, the phone’s screen turn off when it detects when it’s near the useres head, misplacment or damage to that can likely cause this issue.
Was dit antwoord nuttig?
Thanks, Nick. The proximity sensor is where my thoughts went to first, as well. It’s part of the replacement screen assembly, so if it’s askew, that’s on iFixit. Weirdly, the phone seems to be working better with time, with fewer instances of screen blinking. I reckon I’ll give it a bit more time before digging into the innards again.
Voeg je antwoord toe
nxnw zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 119
