Ga door naar hoofdinhoud
Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 Vragen Bekijk alle
Why my 2017 iPad pro rebooting and show green and black line?
My iPad turns off and when it turns on on the boot up screen it shows small green lines and long black lines all over the iPad and now it is on a repeat. The Issue is happening since oct 7th 2020
Is dit een goede vraag?
1 Opmerking
I have same problem. What was the reason ?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That doesn’t look healthy!
We should back up here and you should tell us what has happened to the iPad in the days and weeks leading up to this issue. Was it dropped, repaired or came into contact with water? If you just had random green lines but everything else worked, then it could be an LCD connection issue. However, the boot-looping points to a more serious condition of the logic board.
If you want to attempt a DIY repair, then open it up and check the connections. Keep in mind that you have to be very careful when removing the screen because if you damage it, it is quite expensive to replace. While it’s opened, closely inspect inside to see if there are any signs of water damage.
At that point, you may need to consider if you try a replacement screen to see if it solves the problem but with the cost of this part, it’s usually better to have a shop look at it and eliminate the screen issue for you at little or no cost.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I never dropped it or it never came contracted with water also whenever It gets out of boot loop and I could use it everything seemed to work normally with no issues but after couple of hours it happens again.
door
Hi, did you can solve this problem? I have the same now! Thanks.
door
Voeg je antwoord toe
Arka Baidya zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 613
