Ga door naar hoofdinhoud
WIreless RGB mechanical Keyboard from Logitech
6 Vragen Bekijk alle
How exactly does disassembly even work with this keyboard?
I have the board most of the way apart. The case is open, there are no more (accessible without a rotary cutter) screws anchoring anything together. Am I supposed to desolder the key switches in order to get the board to lift from the face plate or will the PCB survive a little bit of brute force and ignorance? I have absolutely nothing to go on here (I’ve hit a very similar stop with my Logitech G710+ keyboard, but that’s a question for that product’s dealie if a full teardown guide doesn’t yet exist).
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
To remove the face plate you must desolder the switches from the PCB.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
d00m7985 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 705
