What is this component? And how to fix?
Hi all.
So I am trying to repair this iMac for the friend of a friend. Here are the details.
The guy opened it up a while ago to clean out the fans and stuff, plugged everything back in (the screen) and when he turned it back on, the screen came on, but was only black, the Mac bong/chime sounded, and he smelt something burning. He didn’t know what to do, so it sat there for a while. Then he hears from my friend that I work on PCs and some Macs, and asks me to have a look.
I get the mac, plug it in, the chime sounds, screen comes on (powered) but only shows black. I know the logic board is working (at least for the most part) because when I reset the PRAM i get the chime as many times as I want, and the PRAM is resetting, no errors.
So i open her up, and sure enough, there is some heat damage around the LVDS port. I see the reason, the guy didn’t seat the cable in properly when he put it back together the first time. The damage doesn’t seem to be too bad. But it does look like a capacitor/fuse/”filter?” has burn to the point where the solder has melted, and it fell off. (pictures attached) And one that seems to have a little heat damage, but is still in place.
If you guys could help me out that would be great! What is the component? (is it a fuse, a capacitor etc) and how should i go about fixing it?
And yes, I did try plugging the screen in again with all of the cables correctly seated. and all was the same.
Thank you all in advance for your help!!! :-)
Is dit een goede vraag?
8 opmerkingen
It is a Microcontroller, I don’t have experience fixing this part of the iMac, but I do however know how to remove it. You have to get a soldering iron and desolder the microcontroller from it.
door Mason Sayrion
Thank you so much!
Do you mean the one that fell off?
If so, is there anything I need to bear in mind when installing a new one?
Thanks again. :-)
door Nathanael
@dat_one_boi - It's not a micro-controller! It is a MOSFET
door Dan
No, if it fell off, it is just better to buy a new microcontroller. Trying to re-solder it is too hard and you might melt the copper lanes around it.
door Mason Sayrion
@danj Thank you. Which one are you referring to? :-) The one still attached to the board? or the missing one?
door Nathanael
3 commentaren meer tonen
