Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Vragen Bekijk alle
please explain what is the meaning of replacement device by apple
hello for all and I wish all a nice week ahead can you explain to me what is the meaning of replacement device by apple? can I connected to wifi and activate the device and make calls if it is unlocked carrier and free icloud ? ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It means that it is a refurbished device ( most of the time) and it look brand new, If the iPhone you turn in to Apple is sim locked to a provider the replacement device will also be locked.
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
can you please in more simple device if it is free icloud and carrier unlocked can use it as any iphone?
door
Did you revive it for a defect one from Apple? Or bought it some where?
If your got it replaced by Apple and your defective iPhone was locked to for example AT&T then the refurbished iPhone will also be locked to AT&T But if you bought it from EBay or someone else you have to check if there is a iCloud lock or sim lock, I got foulled once , I thought I was iCloud free also checked it but when I got home and want to set up the iPhone it has a MDM lock if you don’t know what mdm means please google it
door
@Leslie Leslie bought it from Ebay
door
Then you have to check it, there are some websites where you can check if its icloud locked and sim locked. And if you alreadfy recived it put your sim in the iphone and see if your sim is accepted and take a look if you can put your own id in the settings.
door
@Leslie Leslie thanks how I can add you a 5 star?
door
Voeg je antwoord toe
tamer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 48
Altijd: 12,495
