Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Vragen Bekijk alle
Why has my reception been bad since I replaced the rear housing?
I recently replaced the rear housing of my iphone 8 plus and I now have really bad reception compared to other iphone 8 pluses on the same carrier. I broke the top antenna flex cable but have now replaced that but still have bad reception. Is the antenna itself located in the rear housing and would that be why I don’t have as good reception? - (when i say reception i only mean cellular reception, wifi has been absolutely fine)
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I had a look and one of the bracket connectors had snapped, so I replaced that and it’s working beautifully
Was dit antwoord nuttig?
Het nuttigste antwoord
Is the housing original or aftermarket? Some aftermarket housings may not have proper connections to use the housing as an antenna.
I’ve read in some posts that adding a bit of solder on the connection points on the housing may solve the problem. Correct me if I’m wrong.
Score 4
Voeg je antwoord toe
Oliver Davies zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 7
Altijd: 88
